help with 2" lift
help with 2" lift
Hi Everyone,.. I'm new to the forum, and I just got my 2010 unlimited x. I want to put a 2" lift on it, to accommodate a little larger tire with more back spacing on the wheel, but I don't know if there are any other alterations needed, as in the steering shaft, or anything. The kit only comes with minimal items, and nothing is mentioned in the directions about altering anything else, but I just want to make sure I don't mess something up.
Thanks to anyone who can help.
JK-Forum Founder
having said that, a good budget boost will come with everything you need and nothing else will be needed. teraflex makes such a kit and i might recommend it.
http://project-jk.com/jeep-jk-write-...ation-write-up
so that it's clear, you want "less" back spacing and NOT "more". more back spacing will bring your tires in closer to your frame and other components and that's not a good thing. less back spacing will push your tires out giving your side walls more breathing room and less chances of rubbing at a full turn.
Sponsoring Manufacturer
hey thanks, guys
my bad,.. less backspacing. oops. i filled out the profile, and i got the spacers put on, so i am good to go. nice height for a short person.
thanks for all the help. it is much appreciated.
