HELP!}}}===>Death Wobble in my brand new JK
which one should i get?....what about steeering stabilizers? do i need one of those? how bout the rear trackbar?....i do have a thumping now in the back now going over bumps..
Originally Posted by wazooz2424
By your description, it doesn't sound like DW. Sounds more like bump steer. What's your PSI? Toe-in and other alignment specs? You will know DW if you ever experience it. Once it kicks in, you have to come to a complete stop before it stops shaking. You'll also crap your pants if you are going fast.
Start with replacing the stock steering stabilizer with a good heavy duty one and your problem should disappear. It worked for me. I'm sure alot of users will disagree but like I said...........It worked for me and was an easy fix.
With 3" in front u definitely need new longer sway bar links, and prob adjustable track bars like jks.
Your sway bar should sit level or slightly up.I bet yours isn't even close.
Don't flex it right now because it will cause your sway bar links to flip..
Your axles are prob 1/2" or more offcenter. Check with a tape measure from frame to point on lug on tire.
And like was said make sure your toe is slightly In, not out, and the track bars are torqued right.
Also did u loosen all the control arms with the Jeep on the ground under Its own weight??
U could have bushings that are bound at stock height..
An aftermarket stabilizer will help, but will only mask the larger problem of what is really causing the DW.
Track bars...any of the adjustables are good. I have F and R JKS ones, the teraflex is nice, it really comes down to how much $$ you want to spend. The aftermarket track bars are way beefier than stock. Sounds like you need a front track bar more than anything....
Back seat thumping....is your rear sway bar parallel with the ground, or is it near vertical due to too short of disconnects ? Also check the rear shocks and rear trac bar bolts for tightness. If you had to remove your brake calipers for lift install, check those bolts as well.
again, I think you have bump steer and not DW. dual stabilizers could fix the bump steer. front lower arms could too. too much air in your tires can cause it. what PSI are you running?
ok heres what im going to do:
new adjustable trackbar front and rear
dual steering stabilizer
extended brake lines front and rear (where can i get these?)
longer sway bar links maybe disconnects (what set should i go with? and front and rear recommended?)
check tire pressure
loosen and retourque all components
alignment
by what everyone has said, i probally do not have death wobble just bump steer and with all of these components i should be able to drive and flex with no issues.
Anything else you think i might need let me know (brands and sizes help me alot)
thanks for all the help
check tire pressure
alignment
Don't know if your kit included bump stops....but if it did the rear track bar bolt on the passenger side could be hitting your bump stop while going over bumps. If so remove the bolt and re-insert it with the nut side toward the back of the Jeep. This will give you more clearance.
check tire pressure
alignment
check tire pressure
alignment
for sway bar links, you should go with JKS quicker disconnects for the front. do not need disconnects for the rear, but you will need longer links. get some fixed lenth links for a 2-3" lift.
brake lines and everything else, call david at northridge4x4.com
sometimes, bump steer is just there and may never go away 100%.
i just looked this lift up. it says it has cam bolts. did you install those? says it has a rear track bar bracket. did you install that? says it has brake line drop brackets, did you install those?
personally, i think cam bolts suck. search for the various threads about them
if you installed the supplied rear track bar bracket, disregard my lost post about ordering one from northridge.
i would forget the above items and simply order adjustable front lower control arms. if you already installed the cam bolts, take those out and weld washers to fix the control arm bracket holes and use the arms. that might fix your issues.
if you dont really need front sway bar disconnects, id get longer rear sway bar links and move the factory rears to the front.
