HELP! @#$%ing Nutserts!!
So I got my Rock Skins from ORE today and spun 2 of the nutserts in the body. Now the mounting bolt is jammed in the nutsert and sticking out about 3/4"...I am at a loss for what to do...Anyone have any suggestions? I am going to ORE Monday morning to see if they can help and return a tool Mel let me borrow.(THANKS MEL!)
Thanks for any and all help guys.
Nutserts should only be installed with the correct tool. You can get the tool at Harbor Freight for about $20.
I know it sucks big time when it doesn't seat all the way and just sits there and spins.
You have a bunch choices... you can tack weld the nutsert to the body or somehow access the back of the nutsert and clamp a set of vice grips on it (if possible) or you can carefully grind the head off the nutsert and bolt and then just push it through.
There are a couple of spots that you have to drill through more than one layer of metal. I just thought i mention that.
Another tip about the harbor frieght nutsert setter: Keep the threads oiled. Put oil or wd40 or whatever on the threads everytime you put a nutsert on it.
To get the one that is sticking out 3/4", this is what id do. Try to pull out on the bolt head and see if the unstert slides out a little, then grab it with a pair of vice grips and try to unscrew the bolt. After that, screw the harbor freight tool into the nutsert a little (not far enough to get stuck) and reset the nutsert all the way. Run a tap through the nutsert and try another bolt.
.......or something like that....
corey d
Sounds good! The tool I am using is actually on loan from Mel himself. It's legit and worked awesome. I think the problem is trying to get 14 little 1/2" holes to line up perfectly to mount these all.
when you install a nutsert the very second it starts to turn and not tighten up STOP THERE. Back the bolt out, spin a correct thread nut on the bolt and add a washer on top of it. Install the bolt back in the nutsert, run it in till the nutsert starts turning. Hold the bolthead with the proper size wrench and turn the washer and nut down against the nutsert with another wrench and it will draw up tight. Don't be surprised if the nut turns the nutsert some, work with it and it will draw up.
