Helf w/ Bumper Install
Okay, I'm installing a new steel front bumper. Now I know how to install and all that, but I cannot get off those f'in plastic screws that keep the grill on JK and I can't get off those two plastic screws that keep the flat plastic piece (which sits between the plastic front bumper and the grill) off.
I turn them counterclockwise, but they don't want to budge...they just keep turning and turning.
How do I get those plastic scews off so I can take the grill off my car and get the plastic cover out from between my front bumper and grill?
P.S. the plastic air damn was easy...I just snapped that junk off
Thank You!
Thank You!
Turn the plastic heads so notches on the outer piece run front to back and the rounded cap has its seam that runs left to right, then carefully slide a small flathead screwdriver under the rounded head to pop out the center, then pull out the edge piece. I have some pictures somewhere if you would like to see them.
