Heated Wiper Blades/ Washer Fluid
Well, winter is around the corner. Since I try to spend time up in the mountains as much as possible skiing, I spend quite a bit of time driving in bad weather. I am trying to figure out what route to go.
Should I do heated wiper blades like Everblades offer? or Should I go the route of heated wsher fluid? or both?
I read the post about wrapping your washer fluid hose around the radiator hose, but I am looking for something more on demand with a switch.
What brand are you using and how do you like them? Post up pics if possible too.
Thanks,
Tim.
Thanks,
Tim.
Thanks,
Tim.
Thanks,
Tim.
I have done the wrap around washer fluid on all my cars, it is pretty much on demand like you say. its cheap and works great.
coincidentally there is a guy who just did the same thing while moving his nozzles tonight in the Modified Tech section, showing what it looks like when its done. All you do is litterally cut the hose, add in an extension piece of tube, wrap it around the radiator hose and then retap it back into the nozzle line. just need the nipples/adapters from hardware/auto store.
Maybe a dumb question ..... But would/could warm(heated) windshield washer fluid cause the windshield to crack on a really cold day if you already have a tiny chip???
Thanks,
Tim.
Thanks,
Tim.
