header question
header question
I have a 2010 JKU. I am new to the Jeep world so please forgive my ignorance here. I purchased my Jeep in May, and noticed an exhaust leak at start-up (driver side manifold is cracked). Once it warms up, it's quietens down. After doing a little research, I was wondering if headers would be the best choice. From what I'm reading it seems that there is very little power gain. Are they worth the extra cost over a replacement manifold? I live in an area of Tennessee that does emission testing, so I have to run catalytic converters (or the appearance of them).
I run HP tuners on my wife's car and mine. Both are Pontiac G8s. Hers is 420 rwhp mine is 464. So I know tuning will help, and my tuner is willing to help with this.
If headers are worth it, which brands need to be looked at and which ones to avoid.
Current set-up on the Jeep is stock motor
2.5/3" lift running 35's
Regearing coming soon and question along with it.
Thanks in advance
Thanks in advance
Don't bother with headers. You won't see real gains unless you're hitting red line and that's not a great idea with the 3.8- it doesn't go any faster or further, just spins a little more. Dorman makes replacement manifolds with a great warranty.
Are you seeing a crack or just surmising that? When I had the 3.8 in mine I had that noise when cold and it went away when the engine was hot. When I took the motor out to put the Chev in I saw the cause of the leak - loose connection between drivers manifold and the exhaust flange. Wasn't the reason I changed to motor so no hindsight regrets here.
