Have a few questions (lift, tires, wheels..)...please help me out!!!
Ha, not a hummer fan. C gussets? I'll read more into it, thanks.
Here's the look I'm after (I'm a two door though)...this is a members Jeep on here...his setup is a 4" RC lift with RC 1.25" BL with 37's on 20's
How about a 2.5" coil lift with flat fenders on 35s? Trying to save you a few thousand dollars. Also consider passengers climbing into the rig on a daily basis.
If you plan to do a lot of offroading:
https://www.rivercityoffroad.com/Pro...e=RKJK35XF-PKG
you can do up to 37" tires with that lift but have to get flat flares
15x8 Cragar Soft 8 steel wheels with 33/12.50-15 Kumho KL71 Mud tires
(but with 35s) about same price from Home - Discount Tire Direct I went with KM2s
if not just do a BB lift for like a couple of hundred bucks to get the clearance.
If you do go over 3-4" lift you might have to replace the driveshafts.
If your jk is manual, axles might be ok, otherwise regearing would pbly be a good idea.
Dont forget to reprogram the thing as well once you put in the new tires.
Oh also if you run bigger than 33" tires and get a spare the factory tire carrier will most likley need to be replaced with either bumper tire carrier or teraflex reinforced tire carrier ...
I myself went throught the same nightmare you are going through just a few weeks back ... gl with the set up
That's what I'm looking for, mostly street but something that can still play a little
Yea gonna check it out
Btw, thanks for the suggestions and help guys, much appreciated!!!
If you really want long arms EVO makes a bolt on long arm but its 4". You could probably do a different spring set up like Rock Krawler if you really want to go up further. As stated above regear should be high on your list and I'm pretty sure you will need new drive shafts if you go up that high. Maybe not immediately but with that angle it puts a lot of stress. You should also beef up your front axle with C gussets. With those big tires you might damage something pretty quick.
Good luck with the build. It's your Jeep!!
If you plan on flat fenders later, I would save the money and but smaller wheels which will make your tires cheaper (even if you get 37's). A 4" lift with 37's and flat are plenty good. You will need the money for gears soon after you change the tires. You will also most likely need a front driveshaft if you do go wheeling. I think you should also weld on some gussets to you dana 30. The gear work should be done at the same time you do your tires and wheels. Most 4" lifts tell you that you need to change the front driveshaft or use an exhaust spacer.
