Has anyone put a switch on their fan?
Has anyone put a switch in line to their electric fan? I want to be able to turn it off for water crossings, so it doesn't break. I was wheeling with a friend who had his fan turn on in water and the plastic fan broke off. If anyone has, which wire did you put the switch on?
js.
Yup, I did. You need a pretty high amp relay (40A+) that's 'normally closed' and then use it on the fan's ground wire. It's a dual speed fan, so it has two power wires. You could always use two relays, one for each hot wire, but it's easier to use a single relay on the ground. You should also consider a waterproof model.
js.
js.
