Half/Tube Doors - lets hear it...
Make your own. I just started on mine. Started with PVC to get measurements right.
Plan on making them out of 1 1/4" square tubing.
Sheet metal where the paper is for mounting hinges and using the side clickers off a tailgate I found in the junkyard. It sounds good lets just hope it gets done by spring.
they are very stout and have adjustments on the lockin mech and the door hinges...they have a zipper pouch on the inside of the mesh part....The arm rest in comfortable...Once you get the latch aligned, it stays aligned....becuz there is nothing to stopp the door from swinging all the way out and bouncing of your fender, the padding on the door touches the fender so unlikely to stratch the paint on the fender...the only thing i would have liked to see is black bolts to match the door. i would have liked to see the bolts on the hinges blacked out or at least the option to get them when you ordered the door...i spend alot of time at the beach and the first thing to rust was the bolts i will be replacing those bolts before i put these doors on the new jeep
they are very stout and have adjustments on the lockin mech and the door hinges...they have a zipper pouch on the inside of the mesh part....the only thing i would have liked to see is black bolts to match the door. i would have liked to see the bolts on the hinges blacked out or at least the option to get them when you ordered the door...i spend alot of time at the beach and the first thing to rust was the bolts
Yeah, I am glad you posted this as well. I really like the look of the RockGear tubes because they start high at the mirror and drop down lower and do the opposite on the rear door.
Keep posting pics guys so we can see all the differences!!
Have 2 sets.
Bestop element with the bags, painted inserts and uppers and a set of Body Aarmor.
Element;
Got these so I could switch between the tube, insert and full. Nice in theory but the paddle handles make that a royal pain. These can be lifted off the Jepp unless you take steps to prevent that. Fit is lacking both on the lower and upper. Uppers leak badly. Welds are not that great.
https://www.jk-forum.com/forums/atta...5&d=1329533531
https://www.jk-forum.com/forums/atta...4&d=1329533529
Body Aarmor;
Suiside look with no exterior handle. Solid, with nice welds. Have a screw pin so you could use a Tuffy or similar lock to prevent lifting off.
Only images I have are being preped for speed gusset painting
https://www.jk-forum.com/forums/atta...1&d=1329535042
https://www.jk-forum.com/forums/atta...2&d=1329535044
Like em both but if I had to pick one over the other it would be the body armor.
Element;
Body Aarmor;
I may also look into ones that don't require OEM mirror spots because I have the relocation brackets so they're just gonna stay there. I see the body armor doesn't have the mirrors which is good. The rancho's do, right?
Originally Posted by FoxRacingJMC
would you like to further clarify you reasoning for that? Haha
