Greasing Teraflex Control Arms..
I changed all the zerks out to 6mm-1 short zerks, I also relocated (swapped the zerk and hex plug) so all the zerks are on the top of the joint. I have no clearance issues now and dont break zerks off. When I need to grease them I just drop one are at a time, grease it, wipe it clean, use a screwdriver to move the joint around a little and get the grease in it, then bolt it back up. Doesn't really take to long.
Red and tacky is fine grease, as are most, I use marine grease, others have there own preferences. I know alot like the white/blue lithium greases.
Yep, 90degree on the top zerk on pass side. What I ment was if you couldn't get to the fitting, just take that end of the control arm loose, not leave it loose.
