Greasing Teraflex Control Arms..
Today I greased my Teraflex lower control arms and noticed that grease only comes out on one side of the joint? Anyone else notice that and is that normal?
Again......clean up your mess!! Is this so hard to understand....lmao just kidding, wipe it up. A clean JK is an easy to servie JK.
Just curious if you had a hard time getting your grease gun onto the zerk? It's doesn't look to me like there is enough room between the zerk and the control arm bracket to get a grease gun on it. I have straight zerks on mine but I noticed the damaged set of arms I had to return had 90 degree zerc's.
Like everyone else one zerk is mounted on top and the other is on the bottom. Either way I have no problem getting them on the zerk as I have a flexible hose on my grease gun. If you are having issues you could always grind down that area on that bracket just a bit to get it to fix.
Also I am using Red N Tacky grease. Anyone know if this is a good grease?
