Grease Zerk and a trac bar
Old 07-19-2007 | 07:53 PM
BLKRuby's Avatar
Default Grease Zerk and a trac bar ++DONE++
Is it possible to add a grease zerk to a FT trac bar? I am tired of having to unbolt every few weeks and grease.
Old 07-19-2007 | 08:00 PM
bajajeeper's Avatar
Pull it apart and cover it liberally with white lithium grease. 5000 miles later no more loud annoying creaking. Good luck.
Old 07-19-2007 | 08:03 PM
usmcdoc14's Avatar
yes, 2 ways
drill hole, tap, make sure there is a hole all the way to the middle, thread in zerk
drill hole, make sure there is a hole all the way to the middle, screw in self tapping zerk
BLKRuby's Avatar
Ah, i have done that 3 times within the 6 or 7 weeks i have had it.
Old 07-19-2007 | 08:04 PM
BLKRuby's Avatar
Can you get zerks at most auto stores? Do they come in different lengths?
Old 07-20-2007 | 10:04 PM
BLKRuby's Avatar
So i did it, i added a zerk to the front trac bar. Super easy and seems to work nicely, deffinatley couldn't hurt.
1. I drilled the hole all the way through the bushings and metal sleeve with a 7/32 drill bit.
2. Clean out the sleeve and drilled hole from any shavings
3. Then i used a 1/4 tap in the hole to thread
4. Screw in new zerk a presto!!
Hopefully no more taking the trac bar out to grease. What a pain in the ass that is!
Old 08-02-2007 | 06:54 AM
mslc10's Avatar
Old 08-02-2007 | 09:51 AM
BLKRuby's Avatar
Ask and you shall recieve. The only thing i would have done different is change the location, i didn't plan that part very well.
[IMG][/IMG]
[IMG][/IMG]
Old 08-02-2007 | 05:29 PM
greggradwohl's Avatar
Where is the correct location?
Old 08-02-2007 | 05:54 PM
BLKRuby's Avatar
the best spot would be about 180* from where i did. that would give the best access to the zerk.
