Grease on Drive Shaft
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Whatever you use for the zerks. ![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
I am using lucas red n tacky, simply because it is the best I found at the local parts stores. There are many good greases out there, just compare the properties. High heat is good, lithium base is good, water resistance is good, etc.
