Grade 8 Bolt Kit Question
I received a Grade 8 bolt kit from Northridge 4x4, I can't figure out where 2 of the bolts go. I received 8 bolts for the LCA's, 4 for the TB's and I have 2 more.. These 2 don't have the gold appearance as the others. Their just zinc or silver looking. Their good sized, I'm installing my Game Changer lift this weekend, I have the front done and I'm wondering where the 2 odd bolts go.
The front track bar for the 2013 and I think 2012's require a different bolt than the previous years, they supplied you the bolts for the pre 2012 trackbar, and the newer trackbar.
Correct. NR and Synergy include a 14mm tb bolt (2 w/ the NR kit) for the 2012 and up font tb. I have a 2012 but will not be using the supplied bolt(s) because I purchased aftermarket track bars and the supplied 9/16 bolts fit much better. Good luck
I'm not sure who had issues with the grade 8 bolts and the metal cloak lift but all the bolts fit perfect with my install. I didn't have any issues with the arms or track bars with the grade 8 set from Nothridge.
