Gorilla Guard Wheel Locks
Old 01-09-2008 | 02:16 PM
aphazia's Avatar
Thanks you for all the replies, guys.
Part number 61681B5 is the Gorilla Guard w/ spinning sleeve in 1/2" threaded Acorn - which is what I need. Took some digging to find that part number, but I couldn't have done it without all of you!
edit: That's the part number for the set of 5, that is!
Old 01-09-2008 | 02:58 PM
TEEJ's Avatar
Talking
What's the difference between the one just above:
http://www.brandsport.com/grla-61681b5.html
and the one at Quadratec:
http://www.quadratec.com/products/15007_03.htm
As far as security goes?
They're the same price....just wondering if it makes a difference if one is at the local shop, and the other isn't?
Old 01-09-2008 | 03:21 PM
aphazia's Avatar
The Brandsport link ( which is what I found as well ) has an internal spline with a spinning sleeve.
The Quadratec has an external spline.
Basically.. with the second one, you stick a custom 'socket' over the entire lug and the pattern is specific. You twist off, and you're good to go. Problem is, I can get yours off if I use a vice grip or hammer a socket onto it.
With the first link, there's a spinning sleeve over a tightly fit internal spline.. meaning I stick my 'key' inside the sleeve and turn - if you try to vice grip, all you do is spin the sleeve.
Obviously, the spinning sleeve set up is more secure. Still not FOOL PROOF. But even more of a deterrent than an externally splined set.
(Yay! Despite being the noob, I contributed to the thread! )
Old 01-09-2008 | 03:52 PM
TEEJ's Avatar
Talking
That site makes me nervous...
You enter Jeep, and it lists that its Izuzu's, but names jeeps, and the Wrangler only goes to 2005, still a TJ.
How were you SURE you got the right locks?
Old 01-10-2008 | 06:01 PM
TEEJ's Avatar
Talking
I ask, because I want to get some too.
Old 01-10-2008 | 11:36 PM
aphazia's Avatar
The part number I listed above is correct - it's the part number for the acorn style 1/2" gorilla guards with spinning sleeves, with a suffix on it signifying it's a set of 5. mine are shipped and should be here early next week.
Old 01-11-2008 | 07:03 AM
Bowski's Avatar
Thanks for all of the info...ORDERED!!!
Old 01-12-2008 | 01:18 PM
cab76's Avatar
Thanks for the info - just ordered the set of 5 spinning sleeve. I had ordered 2 sets of 4 not thinking about the need for 2 keys - duh (I have a hard enough time keeping track of one key).
Old 01-21-2008 | 07:41 PM
S4M14M's Avatar
Any input on how these worked out?
Old 02-04-2008 | 03:10 PM
TEEJ's Avatar
Talking
I JUST got the set of five locks/1 key from Brandsport - took like 3 weeks...
I have to say though, these things are works of art....so shiny.
Shoulda asked for the extra key though too....doh
Yeah - the Quadratec ones are an older design, easier to get off...these...the outer and inner shaft spins if you try to vise-grip it, etc....the key locks the inner to the outer shafts....way harder to get off.
I like'm.
(I will put the regular nuts on when offroading....the odds of dropping that damn (1) key changing a spare in a rock pile is scary)
