Good or bad? One set of spidertraxx spacers?
Not an engineer, but I can tell you that my ESP did not like it.
Well I learned that this was a bad idea trying to drive down a winding back road on my way to the shop. The ESP kicked in several times and the jeep just felt unstable.
What kind of difference you experience with this combination probably depends on the sum of your other modifications. Again, I'm no engineer, but I know the difference in rate of spin between your outside wheel and inside wheels is now greater. Don’t know if having an unlocked or limited slip make a difference in this regard.
Also, you might consider the effects on the stability and roll given that the rear is wider.
How is the rate of spin different? My tires are the same size.
That way if one set was not going to be helping, maybe the other one will....
Maybe, but I was going for the back tires not hitting the same path of the front.
I would be concerned with hopping in and out of the ruts. Might not be enough width difference for that, though.
Thats one way to look at it, but start sawing your front wheels to cover more ground and the linear aspect of having your tread stick out 1.5" more on each side becomes less of a bonus.
And hopping in and out of ruts happens anyways....
[QUOTE=The_Captain;1262920] How is the rate of spin different? My tires are the same size.
QUOTE]
The rate of spin is different because the distance traveled is different while turning.
The outside wheels will always cover a greater distance than the inside wheels due to the whole pieR2 circle thing we all learned about in geometry. Also, the rear wheels do not turn to towards the direction of travel as the front do. Instead, the rear wheels want to go in a straight line which is their path of least resistance. They must therefore be redirected by the forces put on the suspension throughout the entire turn.
By widening the foot print, you are increasing the angle that the inside wheel must be turned at (due to the shorter circumference of its circle) and decreasing the angle of pull on the outside rear tire (due to its longer distance of travel).
You will find out whether or not this is a problem with time I guess.
QUOTE]
