Gonna go for it. MoTech LS conversion.
#42
Great Price!
Holy Crap--that's great!!
i'm looking at the 5.3 LS as well..in the same boat as you--dont want a neck snapper, not gonna drag race, just want power when i hit the pedal.
assume you did the Gen4? did you go with cast iron or aluminum block?
are you going to upgrade axles or drive shafts? i'm still running 30/44s but i did upgrade drive shafts and 5.13 gears.
your build looks awesome.
steve
steve
#43
steve
steve
#44
If you do upgrade your radiator you should consider adding either the pentastar or camaro ss cooling fan. They move a lot more air and really help keep the engine cool. Both are an easy swap.
#45
Actually I have been thinking of having the radiator and fan done when I take the Jeep back down for it's follow-up. MoTech offers a 42mm and 52mm dual pass radiator. Did you go with one of those?
#46
Yes, I had the 52mm dual pass done with the install and just recently added the camaro ss fan. The fan is much nice than the old ones. It comes on when you start the engine so its always keeping air moving and it moves a lot more air. You've probably seen Robbies video doing the fan comparison. I upgraded the fan for when I'm towing my offroad trailer. Haven't towed with it yet but just driving around my temps are lower. Even with just the HD radiator I wasn't having any engine heat problems.
#47
#50
Not too worried about it right now. I'll get it sorted then start keeping track of mileage. I've used Fuelly for a while. Once my odometer is more accurate I'll start again.
