Gobi Rack issue?
Gobi Rack issue?
I installed a Gobi Stealth on my JK this weekend and noticed an issue. I have noticed that the drivers side windshield portion of the rack does not sit against the top of the windshield. The passenger side is snug. This was before and after connecting it to the rest of the rack.
Also, the lower portion of the windshield mount on the driver's side does not sit flat against the front portion of the windshield frame.
I am concerned the 2 issues will allow the rack to move around once it has weight on it. Anyone else run into this? Am I just being paranoid?
TIA
TIA
Call Gobi that is an issue. I have had mine off partially and fully off several times over the years and it always is snug up front.
BTW since I take my rack off a lot the padding under the front part is worn. To have it not destroy my paint I plastidip paint the corner brackets of the jeep.
same windshield gap
I just installed my Gobi rack and both window bump stops don't rest on the windshield? I've loosen every bolt and tighten in a rotating pattern, but no luck. It's sturdy and strong, I've had 250+ pounds on a trip with no issues. I hope its not a huge issue...
