Gm 14 bolt ford king pin axle
I Want to do an axle up grade, but what years should I find for the axle or what car should the axles come out of?
Or what model gm 14 bolt?
Or what ford king pin axle?
Pirate4x4.Com - Extreme Four Wheel Drive
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Shows both essentially in the first bit of the write ups.
But what I am asking is can u swap any year 14 under the jk or are there only certain years? Same question for dana 60 or ford king pin? And what length axle do u go with? And do I want to look for semi float or full float?
They will all work. They will all take work. Go full float. I personally would get as wide as you can like 67 plus but it depends on your plans.
