Getting a little upset!!!!!!!!!
#31
Originally Posted by royone1one
IMO your backspacing has nothing to do with this rubbing. The stamped circles on the wheel is what is rubbing. The stamping leaves a lip on the backside that rubs. I had the same problem with my 15s. Cleared the sides of the caliper but rubbed on the same bar as you. Easiest thing is to grind that bar down a little at a time until it clears.
This is the issue. It just takes a little grinding, no big deal.
#32
I run the 1/4" spacers in the front and 1.25" adapters (like spidertrax) in the back of my corvette. You could call it a "street race" car with no problems. I wouldn't hesitate to do it again either. I only drive that car every now and again though. So I see no reason people should be afraid of spacers. Oh/ and call me crazy but I only check torque on that car prolly twice a year , I put maybe 5k miles a year on it.
Originally Posted by Mad-Hatter
Well, like I said, the spidertrax ones, or others that bolt to your lugs and have integrated lugs in them that you bolt your wheel to are much safer. The 1/4" ones just slide over your existing lugs and you still use them to bolt your wheel to...just have less lug to bolt to now and its shear point is more towards the middle of the lug. Think of it this way, if you have a small tree you are trying to break, its a lot harder to break it at the base of the tree than in the middle of it. I wouldn't be afraid of the spidertrax type since you still get to mount to the base of the lugs on it as I stated.
My .02
Originally Posted by ArkJK
Thanks for all the help guys!! I got the last two sets of spacers that autozone had an got it all put on. I'm only running 265/75/16s but man do they look bigger than my stock wranglers on the moabs. I drove it around the block and am very pleased! Thanks again for all the help!! I don't have a good picture because it's in the garage and I couldnt get far enough away, but you get the idea.
#33
What's up with the alloy usa spacers? They were expnsive so that meen their durable? I have a 4" lift using the stock wheels(moabs) so I needed spacers. I see everyone talking bout spidertracks but haven't heard a word bout alloys? ?
