Getting a little upset!!!!!!!!!
Old 04-13-2011, 05:00 PM
TURTLECON's Avatar
George is getting upset!!!
Try some spidertrax spacers?
Old 04-13-2011, 05:03 PM
wazooz2424's Avatar
Originally Posted by ArkJK
I've got 5" of backspacing just like everyone else with these 16x8 cragars.
4.5" or less is what is recommended. Haven't heard of 16s rubbing though.
Old 04-13-2011, 05:04 PM
4WHLN's Avatar
Originally Posted by ludski
i went to pep boys and got these 1/4" wheel spacers. and fixed the problem. i rubbed my brake too. this fixed it. and never had a problem ever again.
Go get these spacers and your good to go.
Old 04-13-2011, 05:36 PM
mkjeep's Avatar
Edit: if it is a minor rub right there then I say get the 1/4" spacers, sometimes called sandwich spacers. They're $20 per axle and generally not recommended here because people aren't educated enough about them. I personally run these with no problems in the front of my corvette. That car sees more G's than a jeep will, so I think they'll work well for your scenario.
Umm, yeah, these type of spacers are also the reason tire shops will refuse to install wheels with spacers added. More power to you though, I know several hot rodders that use them aswell. As for me, I'd never use them on a vehicle I own. Especially a jeep that see's off-road and a 37in tire being bounced, trounced off rocks and high speed washboard type sections. A 50lb tire rim combo on asphalt is a helluva lot different than a 100lb plus combo bouncing off rocks, dropping down ledges, sidewall stress, etc.
Old 04-13-2011, 05:46 PM
ColdSRT's Avatar
Funny you should mention that. Spidertraxx says for "off road use only". I am in the other school of thought. I would not want them on a high powered street car. I don't think a 1/4" spacer would matter in either application but I still would feel better not having them on a car pushed hard into a turn at speed.
Old 04-13-2011, 05:48 PM
ArkJK's Avatar
Ok i ran to autozone and got some spacers. Dumb question here, but do I need to put them on all 4 or just the 2 front?? I got 4 just in case.
Old 04-13-2011, 05:52 PM
ColdSRT's Avatar
I would do all four. Not that it really matters in the grand scheme of things but it will make both front and rear track width the same.
Old 04-13-2011, 05:55 PM
Coondog33's Avatar
Put all 4 on..just to keep it same on all 4..
Mad-Hatter's Avatar
The 1/4" spacers are just added onto your existing lugs and moves the stress away from the base of the lugs to more of the middle where they are weaker. The spidertrax ones, for example, mount onto your lugs and provide new ones and are a lot safer IMO
Old 04-13-2011, 05:58 PM
Battlefrog's Avatar
Just put Spidertrax 1.25" spacers in today and instantly felt a diff in stability and overall ride....
Quick Reply: Getting a little upset!!!!!!!!!
