Gerry/Gas Can Mounts...
Does anyone know of a gas can mount that will mount up to a factory spare tire rack or bumper? I have seen a few that require a whole new system but nothing simple like described. I was thinking maybe a mount behind the spare that sticks out to one side so the can sits beside your spare. Anybody got anything like that? Pics and where to get it are a huge plus. Thanks.
There are several threads on this subject. I'd suggest starting with this one:
Jerry Can Mounted on Spare Tire
They could probably make some good cash. I would certainly buy one.
I would guess that 95 percent of JK owners have their OEM spare tire carrier and have never (or never will) break it. Haven't seen it as a problem. Like everything else - if it becomes a problem fix it - otherwise it's fine.
I was speakin of those who have larger tires mounted on a stock carrier. Tons of them have broken. That's a problem I suppose you'll never have.
True. Because I know that the stock carrier is for stock tires. If I mount a larger/heavier tire/wheel combo - I'll not expect the stock carrier to hold and will replace it with the proper equipment. Thus the stock carrier is perfectly fine. No breakage peoblem - except for possible user error. But thanks for your continued negative commentary.
