Genright Coilover Mounts With King Coilovers 14"
Maertz, did you ever give them a call? Looking at my axle I'm guessing its a no go unless you have a 3 or triangulated 4 link since the UCA mount is in the way of where a coil over would need to mount to the axle.
I didn't want to spend ton of money on coilovers but I wanted to run longer shocks
So this is what I came up with these are 12" travel and I am right at 11" travel without unseating my coils with a 4" lift
Cut the top off the stock shock tower
Took my metal cloak shock mount and guesset it up
After paint and mounted
Shocks mounted
Flexed on a big rock and you can see that my front end in still level
Shocks mounted
I haven't mounted them yet, but I had somebody CNC me some custom towers for much cheaper than what Genright is selling theirs for.
I can send you the file if you are interested.
Throwing 14" coil overs on a stock length control arm will have other fitment issues not related to the shocks or limit straps. I really think you have to much bs on the wheels to run them out board anyway. You would need like .5" bs wheels on the factory axle.
I have not called yet ive just been looking at lots of set ups trying to see what i can learn. I did look at the rock crawler 3 link set ups as well. Im more leaning towards the 12" travel as 14s seems to be alot more work. I can worry about that way down the road if i finally decide to stretch it at the moment 14s would be overkill.
If you can fit the body of the shock with your up travel then 14" is worth going with even if you are going to limit the down travel. You will have more strength in the shock if you limit it so it is not going to full extension. I have been running 12" coilovers outboard for the last year and they are simply too short. I will be going with some 16" as soon as I can get the rig off the lift and get some weights on the rear axle. With my new double triangulated 4 link long arm stretch articulation will be just stupid.
I don't get what bully has done . he raised the shock towers and that should give him more up travel even though it doesn't look like it in his photos . Without high clearance fenders , what is the point ? He probably didn't have it flexed out in his pics. because the tires weren't hitting the fenders . I woder if it was not flexed out or weather he has some other factors limiting his up travel .[IMG][/IMG]
