General Grabber Reds 35x12.50x17
I'm looking to purchase some new shoes and am aiming for the General Grabber Red Letters. I need a little help though. I am currently running the BFG stock Rubi tires. They're a good tire but they look dinky with the 2" lift that I put on in February. I want a wider tire and possibly bigger. The stock BFG's I believe are 32's. I want the 35's but am worried about rubbing when flexed. Can someone help a brotha out? Let me know your thoughts and or experience.
Only under extreme flexing might you rub. Your list at the bottom says you have the BDS lift - should be fine. You could trim the fenders or go with flat ones to eleviate the problem.
I run 35" BFGs with the TF 2.5" lift and don't rub.
