Gears or transfer case
I have a six speed with 4.10s with 35s will it make my low range lower with 5.13s or a 4.1 transfer case what is better would 513s be to low for a six speed at 75mph
go for the 5.13 gears. the only time you use your transfer case is when you put your jeep into 4x4. the gears are what will drive your tires in normal everyday driving and on the highway at 75mph
if you are happy with 4.10 gears, which most people are going to tell you to change to 4.88 or 5.13, then get the transfer case. but, changing your gears will give you some power back in your engine, and wont perform as sluggish
hope this helps. im stil not sure what exactly you are asking about. gears do one thing and a transfer case does another thing. but ultimately, the gears you have affect the ratios (faster or slower moving) of your transfer case when you are in 4x4. when im talking about speed, im not talking about highway speeds fast, im talking like 5 mph and under.
