gears and regears
#32
Originally Posted by Cwyatt11
How about cold air intake? What are the views on that? As far as is it worth it ? Does it save mpgs? So on...
I put a Banks Ram Air in mine then took it for a test drive, I couldn't keep my foot off the gas, love that rushed air sound, and the throttle response is awesome. It gives me an extra 1-2mpgs, depending on how I'm driving...
#33
CAI are an easy, somewhat cheap, and beneficial mod. They are definitely worth their money, regardless of how expensive they are, which isn't much btw. The gains are usually around 8-12 hp and 10-15lbs of torque, but specs vary a lot with every brand. And as far as saving on gas, it all depends on how heavy your foot is.
I also noticed increases in mpg. About 2 overall. I love the overall sound of both mods and would recommend Banks to everyone.
#35
How easy was the instal?
Gears.. Leave it to the professionals
CAI is a very simple 20 min job you can do with just a screwdriver.
Exhaust is also very simple with basic hand tools. Took me about 30 mins to do a catback mbrp offroad kit.
#36
Yeh, it's easy for CAI install. Particularly easy for the Banks Ram Air because it has an air box that bolts directly where the factory air filter goes, no need to put a new mount in or anything. 15 minutes installed.
Exhaust is also easy, I put a Magnaflow cat-back exhaust on mine with only some wrenches and a pry bar. I did however have to cut away one of the factory clamps on the original exhaust with a Dremel cutting wheel, but only cuz the thing was so rusted it wouldn't loosen up. Bout 45 minutes total...
#37
regear
2007 JK 4:88 and 34".If you don't have to change carriers ( not sure where the break is now but used to be at 3:73 and up) then $1000 each axel at a shop with warranty. A must with bigger tires. Same for brakes. Rotating mass to start and stop!!
