Gears or long arm
So i ultimately plan on moving to 37s after my 35s are done and I have an opportunity for a big mod coming up but I need to decide which one. I'm thinking either regear and locker or long arm upgrade kit. Both will need to be done before bigger tires though
Sponsoring Vendor
Depends on the Year, two door or 4 door.
Why the need for longarm because of 37s? There are plenty of well built rigs with 37s and short arm setups. If you have a good lift now with 35s, definately gearing upgrades first. I had 4.10s w/6spd Rubicon and on 37s for a day. No way I'd live with even that combo.
2010 2 door. I plan to go long arm because the 35s already look a bit tucked up under it with the stock short arms so I'd rather go straight to long arm than adj short arm then long arm. I think I have decided lockers and gears
