Gears Help
Gears Help
I am new to the world of jeeps so dont be too harsh on me!
I have a 08 JK 2dr X. I am putting a 2.5 inch lift on it from teraflex and looking to do 35" tires. I know that gears are needed, but what gears should I get. I drive this on ny highways and around town for the most part, and on the weekends I take it off roading thorugh trials.
Also can someone explain the difference between gears and does anyone know what axles are on the 08 JK X. I believe its a dana 30 reverse in the front and a dana 44 in the rear but im not fully sure.
Thanks eveyone all links, advice and just general information are appreciated.
Originally Posted by onecrazyfuq
5.13 front and rear?
Yes, you have a D30 front (it is high pinion, reverse cut/rotation) and a D44 rear. Make sure you order 'JK' gears, as they are different than the d30/d44 gears from older axles/jeeps. If you are also looking at lockers/limiteds, they are d30 27 spline for the front and d44 30 spline for the rear.
Whether or not to regear just depends on your budget and opinion of how gutless it is. Get the 35's, turn the OD Off, and drive for a few weeks to see what you think.
And yes, you will want to do both front and rear gears. If you only do one end, be sur eto pull the front driveshaft out until you get the other end geared.
