Gears! Gears! Gears!
Ive had these 35's running for about two months now and i cant stand how sluggish this thing is. i need to know what gears i should throw in it and why. i know the talk is 5:13 but is my highway drive shot? Would 4:11 be better?
automatic
4dr
CIA
Exhaust
automatic
4dr
CIA
Exhaust
Not sure about the auto's....but with my 6 speed and 35's, i wen't with the 5.13's. Even with the 4.10's stock i couldn't use 6th gear, and 5th was a mutha even in flat nebraska, goin down I-80 with a tailwind.
The 5.13's now allow me to use 6th gear, in a headwind, going uphill, with the backseat loaded, seriously, i'm not kidding. And at 75 i'm running 3200 rpm....not that bad at all. Go with the 5.13's atleast, and with the auto, i would really think hard about the 5.38's....unless of course you can opt for......a new HEMI
Becaue rubicon has a dana 44 up front and will except the lower gears on a dana 30 which is what comes on everything elese 5.13 is the lowest you can go. I have 35's and 4.10 and it is not horrible but do not spend money to regear to this you will be unhappy.
For those running the km2 35's and 5.13 can you tell me what rpm you are running at 70 with an auto thanks.
I am looking to regear and would like to be about 2500 rpm at 70
Oh ok...im with you on the 4.1 gear set. I'm going 5.13's here in a week, but I have a manual.
I'm another with 35KM2s / Auto / 5.13s
Make sure you get an AEV pro-cal or something to reset your shift points, and I've been extremely happy so far with my gears.
Had them about 1500 miles.
I usually cruise about 75 or so on the freeway and truthfully don't pay much attention to the rpm's.
Whoever put this chart together probably just recorded their RPM's with whatever measured size tire they were using. Unless they used their tire size as a starting point and used math to extrapolate, then it would vary on their tire manufacturer if they didn't actually measure...
