Gears, Axle, Chromoly
Looking for advice on what order I should or NEED to do for performance with a 2010 JK unlimited and stock front dana 30. Regear to 4.88/5.13 first or Upgrade to a Pro Rock 44 on the front Or get a dana 30 chromoly axle kit? RCV performance Axle Shaft? Thanks in advance for your response.
Need to get my profile up to standards here. Picture and specs to come. Thanks!
If you have the cash, don't mind parting with it and believe your wheeling style warrants it, get the ProRock. Otherwise do what you can. C Gussets, truss and Chromo axles will go a long way toward beefing up that 30 and you can do all of that individually meaning, as money is available. Really just comes down to the bank account.
Wow, you know how to push all of the right buttons to get a "discussion" going. LOL. For my response, just look at my mod list (linked in my signature). To see what I do with that Jeep, check out DigitalByDoiron on YouTube.
What gears you have now have no bearing on the prorock unless your asking if you can take all your current components and put them in the prorock and the answer to that is no.
Edit: Ok I think I see what your asking. If you purchase a new differential assembly, the gears in the front must match the gears in the rear for 4wd use.
You don't NEED to do anything. You can just drive it as is and go have fun.
If you WANT to start spending money on the front axle, decide what your goals are. I personally like over-built, but many people just regear and slap on gussets and have no issues.
Why don't you start with listing out all of the things you want, and do a straight up comparison versus a PR44/Tera44? If you can accomplish your goals by putting $1500 or $2000 into your D30, does it make sense 'for you' to dump 5k into an aftermarket D44?
This one has a fairly good comparison:
https://www.jk-forum.com/forums/modi...-build-274896/
Thank you Mark I will check out the mods and youtube.
I'm not sure I follow your question exactly. The prorock is a complete new differential and they sell it as a housing if you wanted to build it yourself or as a built to spec unit complete with gears axles etc.
If you get just the bare housing with nothing in it, you're paying around $2200. This is for people who want to build it themselves, or people who already have a JK Rubicon front d44 - since they can just swap all of the internals into the PR. (since you have a d30, you can not use your current R&P, carrier, inner axle shafts, joints. You can re-use the 32sp outer axle shafts, hubs, brakes.)
If you get the full assembly, you're paying around $5000 (depending on which internals you choose).
Northridge has a decent pr44 builder, but there are more options available than they show here.
Dynatrac ProRock 44 Unlimited Package (PROROCK44UNL_PKG)
The ProRock 44 is an entire new front axle housing, not just the diff.
