Gearing recommendations
Hello, I'm looking for some advice on what gear ratio I should go with. I just purchased an 08 Wrangler X... It did come with some type of 2" lift and 35" tires... I love the Jeep but being a complete noob I didn't know what to really look for in a Jeep. It has the manual 6sd transmission with 3.21 gears... that's what the guy tells me anyways (haven't actually verified myself yet) but I was curious what you guys think a good ratio would be to go with to get some pep into this thing (mainly don't want to have to change gears for every little hill around the house).
thanks,
-Gary
thanks,
-Gary
Do not go by the tire size on the sidewall. Measure your tires from the ground to the hub centerline then multiply x2. This will give you the true measurement of your tires, then look at the chart. Also if you are running a heavy wheel and tire combo you will want to take that into consideration.
Fjeeper makes a very good statement and it is advice, it really will give you a base to start with and what load your engine will actually see. You can go from there.
Before you order a carrier, make sure you check what gears you have. I just upgraded to 4.88's and found that my 6 speed sahara had 4.10's! I didn't expect that, but the 4.88's are perfect for my 35" mtr's.
check out this link....even though you are not doing the install yourself, it will help answer some questions for you and help with all the terms...
https://www.jk-forum.com/forums/show...?82262-Gearing
![sad2](https://www.jk-forum.com/forums/images/smilies/grayno.gif)
![Bleh](https://www.jk-forum.com/forums/images/smilies/bleh.gif)
