Gear swap dana 30 3.21
Old 05-07-2012, 09:08 PM
GulfCoastJeeper's Avatar
Sweet that's what I needed to hear
Old 05-08-2012, 09:42 AM
j33p4lif3's Avatar
just to make sure, no need to change carriers In the Dana 44 rear???
Old 05-08-2012, 12:28 PM
Talked to northridge just a carrier and spider gears for the front, the rear works fine! 120 bucks more. Not bad
Old 06-25-2012, 10:28 PM
Grinder's Avatar
Originally Posted by js16301
I have a 2012 JKU, originally came with 3.21 and regeared to 4.10
Jim
Hi Jim,
Did you buy new or used gears? Can you comment on performance and mpg changes?
I also have same rig as yours and want to run 35s. If you bought used you got them from a JK rubi then right and all that was needed was a new carrier and spider gears?
Old 06-26-2012, 09:31 AM
11REDJK's Avatar
Just dont use YUKON GEARS...went through 2 sets after my gear swap. They are junk IMO...Maybe others like them, but Yukon would not warranty either set.
Old 06-26-2012, 12:24 PM
RSTRICK's Avatar
I have had no problem with my Yukon 5/13 gears I have been running them for 15,000 miles. I use my jeep as my DD and take it wheeling when I can. Sorry you had prob with yours.
Old 06-26-2012, 12:34 PM
jeepmedic's Avatar
I have had Yukons for over 30K with no problems....
Old 06-26-2012, 01:27 PM
teh215's Avatar
Curious, what was wrong with them when you took them out each time?
Old 06-26-2012, 01:55 PM
DeucesALLin's Avatar
Default This looks...
...Like alot of work and money to yank gears. I have heard the same thing though elsewhere on this forum.
Old 07-11-2012, 06:11 PM
cdpeach's Avatar
Just re-geared mine, you'll need a carrier for the Dana 30, 3.73 and up but not the rear Dana 44.
Jim
Jim, where did you get you gears and carrier? Part #'s? I'm in the planning stage for the same gear swap.
Chris
Quick Reply: Gear swap dana 30 3.21
