Gear ratios on a manual transmission.
Old 02-04-2013 | 08:12 AM
Ajk5132's Avatar
Default Gear ratios on a manual transmission.
I have a manual transmission. I put 33" tires on. I have an aev procal. Does adjusting gear ratios do anything on a manual? Should I if I could?
Old 02-04-2013 | 08:17 AM
JK-Ford's Avatar
Just adjusting the ratios in the Pro Cal would be a bad thing if you do not actually replace the gears.
Old 02-04-2013 | 08:30 AM
toofastcomet's Avatar
I have a manual '09 with 35''s and gears. Procal wouldn't let me set the gears. I assume it knows it's not automatic. Just set the tire size and you're done.
Old 02-04-2013 | 08:58 AM
ronjenx's Avatar
Haven't heard of that. Anyone else with a manual run into the same thing?
Old 02-04-2013 | 07:23 PM
HillCountry_Cowboy's Avatar
on a manual jeep the procal will let you set the axle ratio and tire size you have. net result is the speedo is corrected.
