Gear Ratio & Tire Size Chart
#21
Yes, I already have the 4.88. Seems like 5.13 would be too much for manual and 37s especially on the highway
#22
#23
Originally Posted by racin444
According to you sig youre running 35s though. 37s are way bigger than 35s so if you like 4.88s on 35s then 5.13s are the way to go with 37s.
#24
Drive it with the new 37's and see what you think. No sense talking yourself into or out of the new gears before you even try it.
But monetarily speaking, that is a ton of money to drop for a single gear ratio. (if you had an auto, I could understand it, but not so much for a manual...)
#25
As jpop added in the chart above. The higher end of green is where you might want to be if you wheel so my 4.88 on the blue with 35s will be the higher end of green on 37s. Seems like 37s will be good with my 4.88 manual.
#26
Originally Posted by planman
That chart is very misleading because it is based on a manual transmission gear ratio of 1.0. It leads people to under gear their rigs.
Quote: These calculations are assuming a manual transmission with a 1:1 ratio
Automatics have a 4th gear (overdrive) ratio of 0.69.
6 speeds have a 6th gear ratio of 0.84.
The experienced jeepers (who have driven different setups with different gear ratios) nearly always give unanimous answers:
With a non-supercharged engine:
An automatic on 35s or larger should run 5.38s if they drive mountain passes, live at higher elevations, tow anything, or ever plan to upgrade to 37s--especially if they drive a 4 door.
An automatic on 35s that lives and wheels at low elevations, doesn't drive steep grades, or doesn't tow anything should run 5.13s.
A 6 speed on 37s should run 5.13s, and maybe 5.38s if they don't spend much time over 65 mph.
A 6 speed on 35s that is either a 4 dr, or drives at high elevations, tows, or drives steep grades should run 5.13s.
A 6 speed on 35s that is a 2 door and will never upgrade to 37s, or a 4 door that lives and wheels at low elevations and almost never tows should run 4.88s.
There is very minimal debate about this among guys who have had the experience of driving different setups with different gear ratios. They guys who suggest otherwise usually have never driven or experienced different gear ratios.
The shops discourage the 5.13 and 5.38 gears because they don't understand our engines only produce 64 rear wheel horsepower 169 torque at 2000 rpm, at 2500 rpm they produce 88 horsepower and 184 torque, and at 3000 rpm they produce 107 horsepower and 188 ft lbs of torque.
They don't understand that automatics have a 4th gear ratio of 0.69. These mini-van engines need higher rpms to produce enough horsepower and torque to turn heavy 35"+ tires--especially up steep freeway grades or at higher elevations.
Okay, rant over. It is just that every time I see that table on quadratec, 4wd, and other websites, it reminds me of all the folks who wasted $1000-$1500 to gear to the wrong gear ratio--then they believe they need to spend more money on engine upgrades (superchargers, cold air intakes, headers, etc.) because they are not satisfied with the weak performance of our engines at rpms under 2500-3000. They don't even get that the table is based on a 1.0 transmission gear ratio for a manual transmission. They could have almost doubled their rear wheel horsepower if they had just properly geared their rigs to run 3k rpm at freeway speeds.
Thanks
#27
First off thank you everyone for your input and for starting this thread...
I about to re gear from 4:10 to 5:13
Running 35" tires with the possibility of upgrading to 37's ... But I am unsure how bad the fuel economy will be so I may stick with 35's... Anyways...
I drive up a of hills everyday have a ton of extra weight and the way the jeep is now it's gutless ... I decided to go with 5:13 but then a few members said I should go 4:88 or I'll have higher RPM's and I'll have even worse fuel millage.
I'm sticking with 5:13's I feel it's the best choice for this style of jeep with 6sp and 35's
#28
Originally Posted by JPop
Well, here's a preliminary one.
I think it's pretty good guideline and I tried to break things down a little differently than some of these other charts. I also did away with the red they used as I thought it had a negative connotation for what isn't a poor choice, but one that means a good choice for performance.
On the yellow fields and what I determined to be the bottom end of the gear/tire combinations I would note that these are not gear sets that you would want to upgrade to, but rather what you could get away with if you decided to upgrade your tire size.
Whenever you get to tire sizes of 35" and beyond it's best to look to the high side of the green fields or better. This is primarily because I believe the majority of people that take on the expense of 35s or better really do have more intent than just driving around the mall.
This certainly isn't a done deal nor by any means something that isn't open to criticism. I used the dyno information available to determine where enough torque existed to get a vehicle rolling and enough hp to sustain highway speeds.
All RPM numbers are at 70mph.
#29
Originally Posted by patmcd44
You should be fine if you already have the 4.88, however if you haven't done the gears yet and plan to go to 37's, definitely the 5.13 is your best choice with a manual transmission.
#30
The chart in this thread is a little dated and here is the one from the FAQ.
It's not perfect by any means but as useful as any I have seen posted. It's also made it's way to a lot of other Jeep sites and to date no one has provided any detailed information to say it's off base. Of course it casts a pretty broad net, and that is what I believe makes it useful as the end user can pretty much decide what makes sense for their needs.
