Gear Ratio Question
Gear Ratio Question
What is the best gear ratio I should run on my 2009 JK Rubicon.
37', 13.50, 18 Nitto Mud Terrain
Dana 44's
2.5 Skyjacker Suspension lift
Auto Transmission
Do you think i can safely run on the stock 4.10 gears? I do have my computer set properly for the tires and gears with the AEV procal module as well.
Thanks,
Brad
Dana 44's
Auto Transmission
Thanks,
Brad
From an on-road performance perspective, 5.38's all the way. As Jayhawk mentioned, the only concern will be your opinion on the strength. Much more of an issue for the d30 than the d44.
Post #33 in this one is good reading:
https://www.jk-forum.com/forums/show...=1#post2147185
What is better
Does anyone have a prefence in ring and pinion companies. I am about to change my gears out to the 5.38's . My question is there any difference between G2 and Superior and which is better.... Thanks so much
