View Poll Results: what gear combo
35's with 4.88's auto
7
13.46%
35's with 4.88's standard
20
38.46%
35's with 5.13 auto
20
38.46%
35's with 5.13 standard
5
9.62%
Voters: 52. You may not vote on this poll
Gear Poll- 35's
Quote:
Originally Posted by OlegFl
I got 4.10's, auto, and 35's. Hate it on the highways!... I rarely see the rpm's below 2800 - 3000. Getting 5.13's when I can afford it.
You've got it backwards friend
On the flatest of roads with no head wind, it'll run about 1600 to 1700 rpm in OD at 60 mph. The slightest throttle pressure and I'm back in 3rd and around 2500. I need 4:88's
chuck
1 Post
The problem with the auto is the final gear is .69, and the engine just doesnt have the grunt to pull the jeep along with tires in the 35 flavor. With the manual its .84 and that allows you a little more umph in the final (6th) gear.
I didnt vote because I have 4.10's and 35's, but if I was going to do it I would recommend the following due to the RPMS and the ideal final overall gear.
Manual, 4.88
Auto, 5.13
Take these into account and use a gear calculator to decide for yourself. http://www.csgnetwork.com/multirpmcalc.html
Transmission:
NSG 370—Manual, Six-Speed Overdrive
Availability Standard—All models
Description Synchronized in all forward gears and reverse, multirail shift system with top-mounted shift lever
Clutch Hydraulic actuation
Gear Ratios 1st 4.46
Gear Ratios 2nd 2.61
Gear Ratios 3rd 1.72
Gear Ratios 4th 1.25
Gear Ratios 5th 1.00
Gear Ratios 6th 0.84
Gear Ratios Reverse 4.06
Axle Ratio 3.21 Std., 4.10 Opt. (Std. on Rubicon)
Overall Top Gear 2.69 Std., 3.44 Opt. (Std. on Rubicon)
Transmission:
42RLE—Automatic, Four-Speed Overdrive
Availability Optional
Description Electronic governor, electronically controlled converter clutch
Gear Ratios 1st 2.84
Gear Ratios 2nd 1.57
Gear Ratios 3rd 1.0
Gear Ratios 4th 0.69
Gear Ratios Reverse 2.21
Axle Ratio 4.10
Overall Top Gear 2.83
Manual, 4.88
Auto, 5.13
Transmission:
Transmission:
Gear Ratios 3rd 1.0
Axle Ratio 4.10
Automatic 2010 JKU, GET 5.13!!! I just got them put on today... couldnt be happier!!! in city driving is much improved! havent had a chance to test high way too much yet... Definately worth the price! Get them with Dave at Northridge!!
Thread necro! You might want to check dates on all the gearing threads you're posting on, I've seen three so far (was wondering why so many people had gearing questions all of a sudden...)
