Gas savings??
Old 07-01-2011, 12:22 AM
  #101
zaxxs's Avatar
If you have alot of miles on your jeep it wouldn't hurt to have a tune up.
Old 07-01-2011, 03:53 AM
  #102
cyberbrain's Avatar
in my JKU I have 3.73's and 35's, and I consistantly get 15 to 17mpg. Not to bad, but I am debating on regearing to see if that helps mileage any.
Old 07-01-2011, 04:31 PM
  #103
jeepcanoe's Avatar
Originally Posted by Red Stinger
You can say don't tailgate.... but if you ride close behind a semi it saves some serious gas haha. I've gotten mine up to 25 mpg going 55 behind a semi
I see your point about using the draft but this isn't nascar. Bad choice for the all the shit that's kicked up
Old 07-01-2011, 04:48 PM
  #104
jeepcanoe's Avatar
Originally Posted by TheDirtman
The is no such thing as a tune up on a modern vehicle.
I believe he was referring to fluid and filter changes, tire pressure all that fuel mileage stuff related to the post. the wide use of fuel injection in mass production was sometime in the mid 80's. It was use on specific models as early as the late 50's.
Old 07-01-2011, 05:40 PM
  #105
Freewill's Avatar
Originally Posted by DEADGUY11
1. make sure truck is well maintained
2. use synthetic fluids when applicable
3. remove as much weight as possible "within reason"
4. drive as smooth and light as possible
4a. If you have a tuner put it on an economy/mileage mode
You might get a mpg or two from doing these things. Driver mod will net the most if you drive irratically and or way above the 65mph range.
That's four darn good ideas.
If you use the rig for DD, leave as much gear on the garage floor as possible during the week.
Also, a Wrangler has the areodynamics of a brick so relax and keep the highway speed down. The loud pedal is the enemy if you want to save fuel.
Finally, consider a second set of wheels with "all season" tires. Use them to commute; change wheels for the weekend. You won't look as cool, but oh well.
Old 07-02-2011, 06:06 AM
  #106
sciguy6's Avatar
Have a K&N and regular tune into wind about 18 mpg (16.5 last time). Set my Predator Sport to 87 tune and with a very slight side tail wind had 22 mpg. will take a while to pay off in gas savings but the extra 20 torque is worth it, especially when towing or driving into the wind.
Old 07-04-2011, 01:08 AM
  #107
skisailbike's Avatar
I just drove 1200 miles, all highway, across mostly flat land, and kept close track of my mileage. I'm on 37x13.50 Mickey Thompson ATZs, at 28psi, and 5.38 gears with an auto. At 65 I got 13.8 mpg, and at 75 I was down to 12.3 mpg. Most of the trip was into a 15mph headwind, so that didn't help at all. I'm making the same trip in reverse this week, and hope the wind cooperates and I have a tailwind going home!
Old 07-04-2011, 07:39 AM
  #108
ink42o's Avatar
It is all driving habits. I have a 07 jku with 4:10 gears and 35" MTZ tires. And in 6th gear at about 62 mph I have average around 20 mpg. I just did this driving out of town 4 hours each way. My wife has a 09 2dr with 3:21 gears with 33" tires and I can do the same with her's in 5th gear at 65 mph again I can average 20 mpg.
This is a photo of my peak mileage from our trip this pasted weekend in my jku.
Old 07-04-2011, 08:29 AM
  #109
Mark Doiron's Avatar
Originally Posted by ink42o
It is all driving habits...
Driving habits are part of the equation. So is physics (larger tires, greater mass and moment arm, greater energy consumption). So are weather and terrain. So is speedometer calibration (rarely does my MPG indicator show within 10% of the actual, hand calculated gas mileage). So is quality of gas. So is vehicle weight.
I saw my MPG numbers vary from 10.6 to 17.2 in a trip to Utah this past couple weeks. Trying to compare your numbers and mine or anyone elses is an exercise in futility.
Quick Reply: Gas savings??
