Gas Milage
Remember that if you don't have the computer (odometer) flashed for bigger tires you lose MPG as the Jeep reads one revolution as a shorter distance than it actually is.
Look for "tire size MPG calculator" online. I lost 8% mileage in the switch from stock to 31's.
Either the dealer can do the flash or get a Superchips to make the adjustment.
2 door x with 3.5 inches and 33s. My speedometer and opometer are not calibrated but according to them im getting 11mpg I hope that im getting more like 15
Not sure about your X, but mine came with a 255/70/17 which is a 31" tire. Also saying 8% doesn't mean jack truly, that could be a wide range depending on what you got prior to your tire swap. Considering what you should get, would be a little easier to say you lost about 1.5 MPG.
The point is that you need to account for the difference in tire size in your hand calculations. If you don't - your calculation will show a loss of mileage that is not accurate. The weight of the larger tires will cause actual loss in MPG, but the increase in size without the adjustment will show a loss in MPG's greater than the actual loss because the odometer is not calibrated for the larger tire. You can adjust by recalibrating the computer (flashing) or add the % difference (in my case 8% or about 1.5 mpg).
I have 35" KM2's with a 3:73 gear ratio. In a week or so I'll be re-gearing to a 5:13 setup. I have an Auto tranny as well. In the City I get about 11 MPG and 15 MPG on the highway. I will post my findings with the re-gearing.
I am running 35s on stock gears with a manual getting about 13.5 round town...aweful. My 4.88s just arrived so in a month I'll give you the latest on the improvement I am hoping for
