Gangster Lean
Gangster Lean
I came back from the Rubicon and my jeep is leaning pretty good on the passenger side. I know jk's are known to be a little heavy on that side, but this is way past a little. I tried to adjust my coilovers and it only had minimal impact.
Is it possible the rear sway bar is bent?
Thanks in advance.
Thanks in advance.
Mine developed a mysterious lean to driver that turned out to be caused by a twisted Full Traction rear sway bar. Reinstalled the stock rear bar and threw the FT POS in the dumpster. No more lean
That confirms my suspision. A factory replacement is only $99 bucks. I'll pull off the sway bar and check it out.
