Full Traction Short vs Long arm??
After 6 months of reading forums and memorizing catalogs, part numbers and websites I have finally decided on Full Traction. That being said I have narrowed it down to two of their kits.
4" Ultimate
or
4" Long arm
I want to run 37" tires and both of these will get me where I want to be. So I guess the question is;
Is the long arm kit worth it? Does it peform that much better?
The $800 price difference isn't the deciding factor for me, its the switching to long arms and the added effort to install.
4" Ultimate
or
4" Long arm
I also have been looking at the Evo flip kit or the Full Traction steering correction instead of just a dropped pitman arm. I think its the removal of the stock control arm connection points that has me un-easy.
The long arm will mostly benefit in greater on road quality. My short arm kit has 11" of front and rear travel. The ammount of flex you have comes from the length of your shocks and bump stops. The stock JK arms are quite long for a short arm, so if you want a better road quality then go with the LA. I have been running my 4" Currie kit with all the fully adjustable arms for 11 months and my front drive shaft is still going strong! It all depends on how you adjust your control arms that affects your drive shaft life. Now with the 11" of front travel, my drive shaft boot will contact the exhaust cross over pipe at full droop. The long arm will have nothing to do with your drive shaft angle. The long arm will offer a better ride on and off road and can offer more flex and travel if you get the right shocks.
Thanks for the info. 11" of travel! Ill make sure I ask the right shock questions when I place my order. Thanks
Any idea how much travel bone stock?
No idea how much the stock travel is. Someone on here knows im sure. If you get either Full Traction kit the shocks they sell are designed for their kit. They wont give you too much or not enough flex.
Are you planning on installing the kit yourself? Or having somebody else do it? I want to get the FT LA kit....so you should get it before me. So I can use you as a guinea pig.
Ever hear a guinea pig scream when you rub its hair backwards?
I was up between 2 kits FT and Teraflex when I bought my kit. I like FT products both kits are top quality. I have 2 guys I wheel with and one has the FT add on LA kit with the SRS bushings on 3 inch FT springs and his brother with the 3" premium plus. Both kits identical but arm length. Shocks and all, the LA kit rides smoother at speed on and off road. We installed it in a good day (10 hours) with normal tools, no special torches or lift. Grinder works great with a lot of patience. Good luck, my vote is do it once and do it right. go long arm
Go long and you will be a happy camper.
Check this video out!!!!!!!!!
http://www.youtube.com/watch?v=uRjK9...feature=relmfu
