Full Traction long arm Suspension Systems
Old 01-22-2010 | 12:49 PM
  #51
highoctane's Avatar
Originally Posted by crowsjeep
I just found the FT lift today, been shopping for a long arm. I was going to get a Teraflex until I downloaded their instructions. Pretty vague, no real way to line up the front bracket had me worried a bit. The bolt on FT instructions are great, Teraflex should take some lessons or figure out how to line their bracket up with an existing hole or something, if they did I would of bought their lift by now. This FT lift is a little more, but being bolt on sure will be easier for me to spend the extra money for it.
Thanks you god for jk-forum and internet
Thought I'd post up just to give some info. The Teraflex control arm brackets DO indeed use existing boltholes in the frame to align the brackets. On the front brackets it uses the auto tranny crossmember bolt hole on the bottom of the frame, and the two bolts on either side of the front end of the tranny cross member. Bolt the brackets in then weld them, no way at all to screw it up. On the rear passenger side it uses a bolt for the gas tank skid to line it up, again its damn near impossible to screw it up. On the driver side rear there are no holes to align the bracket, so you must measure the pass side. There is a rib on the frame rail that the new bracket has a slot in to clear it, I measured there. Line up the driver side bracket using those measurements, tack weld in place, verify, then weld on. I did mine at the auto hobby shop on base using a 2 post lift. Did it with a coworker. Took 2 days of 9 hrs each. Just wanted to clear up some misinformation.
When it comes to long arms Full Traction and Teraflex were the only two I ever considered. Both are excellent kits! Full Traction is a HUGE plus if you dont know how to weld. Also a plasma cutter will knock off about 8 hrs of the install time. That's how long it took me and a coworker to cut off the stock control arm brackets with a grinder and cutoff wheel.
Old 01-22-2010 | 01:19 PM
  #52
Piginajeep's Avatar
Originally Posted by highoctane
Also a plasma cutter will knock off about 8 hrs of the instal time. That's how long it took me and a coworker to cut off the stock control arm brackets with a grinder and cutoff wheel.
yup, I had about that in cutting and grinding mine off.
When i helped install the rockkrawler long arm, we had access to a plasma, It took all of 5 minutes
Old 01-22-2010 | 01:22 PM
  #53
rinkishJK's Avatar
i cannot wait until i got enough saved to get the ft kit!!! plus if something were to get messed up u can bolt in a new part instead of having to weld.
Old 01-22-2010 | 01:51 PM
  #54
Piginajeep's Avatar
Originally Posted by R8R ROK
Who needs a plasma torch when you have good friends and plenty of beer for afterwards.
you have better friends than me, Mine would drink beer and watch
Old 07-29-2011 | 09:23 AM
  #55
jp chen's Avatar
what is 4 inch lift long arm axle angle 2door jk
thanks so much
Old 07-29-2011 | 11:21 AM
  #56
jp chen's Avatar
same is 4 inch lift long arm axle angle??
How long to adjust their??
Thanks so much
Old 07-29-2011 | 06:10 PM
  #57
jp chen's Avatar
no body know it?
Old 07-29-2011 | 09:11 PM
  #58
KenB1010's Avatar
thanks so much
Are you asking about caster angle?? If so, it should be between +4.2 (stock) and +6.0 degrees. More caster will get you better drivability at the expense of longevity. Less caster you will have better longevity at the expense of drivability. In other words, it's a compromise.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old 07-29-2011 | 10:20 PM
  #59
jp chen's Avatar
thanks so much
This is what I want
im from 4inch short arm Upgrade to long arm
Quick Reply: Full Traction long arm Suspension Systems
