? for FT Long arm owners
i'm going to be installiing my full traction long arm hopefully within the next 2 weeks. can anyone that has one tell me where the gas tank skid needs to be trimmed? is it where it meets the new crossmember or at the rear arm mount? any info or tips in installing this lift would be great! thanks in advance.
Send eDivebuddy a PM, or maybe he'll chim in.. He's currently installing one and took tons pictures along the way.
I waited until I had the tank back in place and cut it off. it takes about 20 seconds with the cut off wheel.
Tips, get some good drill bits, and a pack of good cutoff wheels. If you need anything send me a PM. I helped Edive along the way.
thanks Piginajeep... i looked over your gallery with the pics you took during your install. i think it is just going to be a little time consuming, but will be well worth the end result. thanks again.
But worth it in the end. i sent Edivebuddy a PM, I'm sure he'll chim in with some pointers. I'll take a measurement of the skid in the morning.
![Cool](https://www.jk-forum.com/forums/images/smilies/cool.png)
There's more not in the instructions. You need to trim the cross member brackets to clear the welds. You also need to trim the body mounts to clear the welds for the rear control arm brackets. I have pictures I'll post later of these.
Make sure you have all the hardware and the new instructions. They don't tell you where every bolt goes but they are grouped in the instructions.
You'll also want to protect the brake lines on the drivers side when you cut the control arms off. I zip tied a piece of aluminum strapping to it just in case.
Get a tie rod end separator. If you can find one. Don't use a pickle fork if your jeep has seen a winter, you'll just have to replace your boot and it can take for ever to get off. I could not find one so I took the tie rod off and used a pitman arm puller. I put a chisel on it so as not to strip out the hex hole.
And while you have the transfer case skid off might as well change the fluid there too.
I work six days a week, but I will answer any questions you have if I can.
It's a lot of work and my arms are tired, but I'd do the work again.
the connectors on the tank, just push them in with your fingers, they actually are easy once you figure them out...
I didnt cut have to trim the cross member brackets, I just beat the bastard on with a mallet
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
I broke two step bits and killed three 1/2 inch bit's. I did have to drill out my front sway bar though as I put my Currie adjustable sway bar links back in.
That's where all the work in this kit is. It took me 5 hours a side for the front. Don't even bother with getting any grinding wheels, just cutoff wheels it will go faster.
He sure did! I got stuck a lot of times, I didn't want to start a step without knowing what the whole process was, and the instructions skip a lot of things.
i didn't mean to post and run guys... thanks for all of the helpful info. it will definitely help me out when the time comes! i will be doing this install with just a jack and jack stands... lol no lift for me unfortunately! it will be a bit more time consuming, but i'll be fine! i won't be using a pickle fork for the drag link... never liked using them... they always pretty much destroy the grease boot! thanks again for the advice, and wish me luck!
i hate to bring this thread up from the dead again, but i started my install today. everything was going pretty smooth until the grinding began on the control arm brackets. what did everyone else use to cut these things off??? it takes foreeeevvvvvvver!!! i don't know... i got the front crossmember to go in without any issues, it just seems like cutting away the control arm brackets is a huge stalling point... i don't know how many times i said i wish i had a plasma cutter today!!!! oh well its only time... the end result will be worth it! so... to anyone who did this intstall themselves, what did you use to cut these damn things off??? any info or tips would be great!!! thanks again!
Protect the brake lines on the drivers side upper control arm and the wire loom on the passengers side upper.
You can find some stuff that was not in my instructions here
http://my.project-jk.com/showgallery.php?cat=1843
Good luck, it's well worth the effort!
