FT 3" Ultimate -- Lessons Learned.
Old 08-31-2007 | 06:38 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by Rubidonn
So the question is: obviously with a HD spring, my front will come up a little... Is the ride much different (stiffer)... and when going off road, I would think that w/a HD spring, I might not get as much flex... just seems logical (stiffer spring = less flex)... is this the case or is the difference negligable?
-Thanks-
Without the added weight of a heavy duty steel bumper and/or winch, you might find the ride to be stiffer. But, with the added weight, you shouldn't see much if any difference. As far as flex goes, the coils may be stiffer as your logic dictated but it's not enough to affect your flex.... trust me
Old 08-31-2007 | 06:50 AM
Rubidonn's Avatar
Thanks for the info.
I've got the AEV bumper up front... so I've probably added a good 100lbs up there... I've probably put at least double that in the back w/my Rock Hard bumper and tire carrier w/hi lift... so the rake hasn't been bad.
I guess I'll just keep this option open in the future if/when I get a winch.
Old 08-31-2007 | 07:20 AM
myorbital91's Avatar
HD coils??...damn...
Old 08-31-2007 | 07:34 AM
Rubidonn's Avatar
BTW, any idea how much [additional] actual lift you end up w/ between the two springs? Probably has to do w/how much weight you got up there. Somewhere i heard 1-1/2 to 2"... W/the rake I have right now... not really sure I need/want that much extra.
Old 08-31-2007 | 07:52 AM
wayoflife's Avatar
JK-Forum Founder
Yeah, it really does depend on how much weight you have up front. Essentially, I think the difference really needs to be looked at in terms of, how little sag you will see.
Old 08-31-2007 | 08:14 AM
Jeephrog's Avatar
Rubidonn - I think you have lost close to 1/4" -1/2" of lift due to sag since your rig "appears" to be slightly taller than mine when parked next me.
Just wait til I get my bumpers and you'll look taller again
We need to park them together out on the level parking lot and get a good look.
Old 08-31-2007 | 08:16 AM
bly109's Avatar
I always see Front HD springs mentioned because of the weight of a winch and bumper. But what about the rear? Do they make HD spring for the rear? Or is the spring rate already high enough to account for a heavier bumper, tire carrier, bigger spare, posible rack.. etc? I know they already take into account cargo, passengers, possible trailer into the rear equation, but is there still a need for HD rear springs?
Old 08-31-2007 | 08:19 AM
Rubidonn's Avatar
I think that is probably about right... If the HD fronts would raise the front 1-1/2 to 2", I think it would be too much for my liking. Could be wrong.
Maybe we should get the JK's out of the parking garage and put them in the front lot?!?!
wayoflife's Avatar
JK-Forum Founder
No, there are no rear HD coils and mainly because they would ride way too harsh when unloaded. If you load up your Jeep to go camping, a saggy rear end is something you should expect with any lift. But..... I can tell you that I am working on a solution for this and hope to post my findings in about a week
Old 08-31-2007 | 11:53 AM
mikeyfl's Avatar
Originally Posted by mmccurdy
Toyo Open Country M/T 35x15x13.5's on steel wheels w/ 4" backspacing (as pictured in early FT promo shots) will rub under trail conditions. I shimmed the rear bump stops up by about 1/2" on stacks of washers, and this helps tremendously, but they still rub occasionally (maybe this is "normal" but it surprised me)
where does the rubbing occur? i have these wheels, but with 3.75bs.
Quick Reply: FT 3" Ultimate -- Lessons Learned.
