FT 3" + 35's -- RUBBING under trail conditions! What can I do?
Old 04-23-2007 | 01:01 PM
  #31
popo's Avatar
Default Rubbing
I run stock wheels and 1 1/2'' wheel spacers, same lift, and same tires as you. I rub a little on front bumper, got rid of it for a pj bumper, no rubs now. Did Moab and hells kitchen not a problem. There is something wrong with the install. I installed mine myself and good shop align it. good luck.
Old 04-23-2007 | 01:11 PM
  #32
Eracer76's Avatar
Originally Posted by Northridge4x4
Did you install this kit?
Originally Posted by mmccurdy
Yes. If I recall correctly, it just said "install the sway bar links using the included hardware," so I didn't think much about it at the time. There was no hardware left over when I was done.
A few posts back you said a shop did it and you werent happy with them.
Not all shops are good at what they do, some think they know everything and just slap it together and ship it, without even looking at the directions from the lift kit. I bet they had extra washers left over and just pushed them aside and said its good to go
Good luck and I hope you get it all worked out soon
Old 04-23-2007 | 01:14 PM
  #33
Rubimon's Avatar
I think you're exactly right on both counts.
Re: the sway bar, I'm just hoping the recentering will happen naturally (it seemed very hard to slide by hand when I tried it). It does not compress enough to get the sway bar to brake hose rubbing on the street, so I'm not too fussed about it for the time being.
Re: the loading issue, I think that's exactly what's happening (the bump stop just compressing more), so that's why I'm hoping my shims will work.
Again, I feel like I should say that I'm overall very happy with the whole setup, and this thread is not meant to be taken as an indictment of Full Traction. If you're been following along at home, you'll note that many of the issues I've raised were either self-inflicted, the result of a negligent shop, or a simple problem of my expectations being in the wrong place relative to marketing materials, etc. and not the fault of Full Traction at all.
In a nutshell, I understand that I'm an "early adopter" here, so my only hope is that others who are considering the same setup will have a few more things to know and watch out for when they do it themselves. That's why the forum exists, right?
I agree with you fully and appreciate your posts.
As far as recentering your axle you will probably have to get a ratchet strap (costco or where ever, everyone should own a pack anyway if you don't already) find a couple of sturdy points to hook up to, and pull it over to center. Stand a level on the tires on each side until you get the same measurement to the fenders and then adjust your track bar to the length it needs to be.
Old 04-23-2007 | 02:15 PM
  #34
mmccurdy's Avatar
Man, that ratchet strap thing is a really good idea! Where were you yesterday when I was using the "lie on your back and place your foot on it and push with all your strength" approach to center the axle
Above, I was referring to the sway bar not being centered due to a previously misaligned axle, though I think the ratchet strap thing will work there as well assuming it doesn't eventually float with the axle to fix itself.
Old 04-23-2007 | 02:21 PM
  #35
mmccurdy's Avatar
Sorry for the confusion. I did the original install, and I took it to a shop for alignment and safety inspection (same approach popo took a few posts back).
Old 04-23-2007 | 02:36 PM
  #36
Eracer76's Avatar
Oh, now I see...
I wonder if your rubbing has a little to do with the fact that your running a 13.5" wide tire, where most people are useing 12.5" wide tires on 3" kits?
Old 04-23-2007 | 02:41 PM
  #37
wayoflife's Avatar
JK-Forum Founder
Yup
Actually, if you just disconnect your sway bar links and then rotate the sway bar it self up and down while pushing or pulling in the direction you need it to go, I think you will find that you can move it without any special tools.
Old 04-23-2007 | 02:48 PM
  #38
CLACKEY(_!_)'s Avatar
Oh, now I see...
Here's a quote direct from the Full Traction website on what it will clear.
2007 JK Wrangler 3" Economy Suspension
Our Economy 3" Lift is the simple and inexpensive way to clear larger tires up to 35x12.50*, increase ground clearance, and improve suspension articulation without major drivetrain modification. While designed to keep the cost low, this kit is complete and correct. Kit includes: Front and rear springs, front track bar bracket, rear track bar bracket, front & rear sway bar links, billet aluminum bump stop extensions, brake line extension brackets, and complete detailed instructions. System can be ordered with Full-Traction 5100 series Hydraulic shocks or M-Force Gas Monotube shocks. Precise, comfortable street handling, combined with great off road performance make this an excellent choice for a daily driver.
* Using recommended tire widths & wheel backspacing
Old 04-23-2007 | 02:50 PM
  #39
Rubimon's Avatar
Yeh, but I think he is trying to pull the ass end of the Jeep over to get the wheels centered. Then he can adjust his track bar to the length he needs.
Old 04-23-2007 | 02:53 PM
  #40
Rubimon's Avatar
I was watching McGyver reruns!
