FT 3" + 35's -- RUBBING under trail conditions! What can I do?
#21
Quick update on this...
I pulled the wheels and dropped the axle yesterday in an attempt to fix the rubbing issue. I found a few (others) things of concern. This is all on the rear of the vehicle:
- My rear track was off by probably 3/8 - 1/2" (shifted toward the driver's side). In order to fix it, I pretty much had to tighten the track bar heim joint all the way in so there are no threads exposed.
Side note: I had asked a shop to look at this among other things, but they obviously did not. They also failed to tighten down two jam nuts on the control arm heim joints, even though they made a big deal about how important it was when I went to pick the Jeep up. If you live in the SF Bay Area, I would not recommend Arabia's Overkill in Campbell. Also: I'm also looking for a good shop (would travel to East Bay, etc. if needed).
- The sway bar was rubbing pretty badly on the brake hose hanger. At first I thought this was due to the track being off, but after adjusting it I'm not so sure. It only rubs on one side.
- The bolt heads for the sway bar links have pretty much embedded themselves in the rubber of the bushing. It really feels like there should be a washer here or something. It's to the point where it was very difficult getting the bolt out and back in again because I have probably less than 1/8" of surface to get a socket or wrench on.
Finally, here's a pic of my low-budget bump stop "extension extension." A stack of 8 washers extends it almost exactly 1/2". If this works to eliminate the rubbing, I'll buy/fab a block of aluminum or something to use there instead.
Also, going back to my original question about how loaded up you were on the trip, you are aware that the yellow bump stop does compress quite easily right? I mean, the rubber can literally squash down to half it's height or more and when you've got a real heavy load, it will. Is it possible that if you were loaded a bit lighter, the bump stops would have done their job without the extra help of the washers?
#22
#24
Your sway bar is held in place by rubber bushings and it can slide side to side in it. If your track bar was off that much, your sway bar most likely shifted over to one side causing the problem that you have now. Give it a closer look and I think you will see that I'm right.
Hmmm, I just checked my rear sway bar links and I do not have this problem. Is this just on one side or both? I'm wondering if the sway bar shift caused the bolt to dig in like that.
Just out of curiosity, did the rubbing occur only on one side? Is it possible that your axle shift due to the improper adjustment of your rear track bar cause the rubbing?
You know, I forgot to mention this, but I also did some "simulated flex" experiments yesterday and I could not replicate the rubbing in the driveway. Basically, I took one of the springs out, installed the tire, and jacked that half of the axle all the way up as far as it would go. The bump stop bumper compressed quite a bit, as you mention, and I kept going until it lifted the frame off the jack stand.
Then I made sure that the other half of the axle (spring installed, no tire) was sagging as far as the shock would allow.
Under these conditions, I could spin the tire freely in the wheel well, and I probably had 1/2" between the front edge and the metal tire gouger (but less between the top and back of the fender).
I figured the bump stop bumper might compress a little bit more if I literally dropped a full Jeep on it, so I assumed that's when the rubbing on the top of the fender well occurred.
I could not, for the life of me, figure out how the control arms would allow the axle to move far enough forward to rub on the front or back of the fender well. There is a tiny bit of compression in the rubber bushings, and maybe an aired-down tired might deform a bit from centrifugal force, but other than that, wtf?
To answer your question directly, I had a fair bit of gear in the car, but it was all pretty standard stuff. Cooler, sleeping bags, handful of tools, water. The Jeep was not sitting noticeably low or anything. I would ask again though: why should it matter?
#25
#27
#28
#29
I think the load should matter. Obviously, the different loads will affect the compression of the bump stops, springs, etc. I think under most circumstances the 3" lift and 35's is not causing this problem with many other Jeeps, at least none that I have seen. If you are going beyond what people normally wheel with you should take that into consideration and get heavier duty springs, etc. But then you will screw with the comfort of your daily drive. My house is wired for so many lights, outlets, etc. but if I bring in a few bigscreens, a soda machine, karioke machine, etc, etc for superbowl sunday, I am going to be popping breakers.
I am just saying that it shouldn't really rest on Full Traction to provide a lift that works under every type of load condition. I know my Jeep sits quite a bit higher than a lot of others that have their hard tops installed and have aftermarket steel bumpers/tire carriers.
Sorry for rambling.
As far as your washers go, pick a couple up at the hardware store. The guys that installed your lift probably still have yours in a pile somewhere. Its just a regular washer.
Sorry for rambling.
#30
However, with the extra load, the bump stops might be squashing down even more under the heavier impact and thus cause a tiny bit of fender rub. I don't know, maybe I'm stupid and don't know what the hell I'm talking about but as I said before, I have not had the problem you experienced and so I was just trying to help figure things out.
Re: the sway bar, I'm just hoping the recentering will happen naturally (it seemed very hard to slide by hand when I tried it). It does not compress enough to get the sway bar to brake hose rubbing on the street, so I'm not too fussed about it for the time being.
Re: the loading issue, I think that's exactly what's happening (the bump stop just compressing more), so that's why I'm hoping my shims will work.
Again, I feel like I should say that I'm overall very happy with the whole setup, and this thread is not meant to be taken as an indictment of Full Traction. If you're been following along at home, you'll note that many of the issues I've raised were either self-inflicted, the result of a negligent shop, or a simple problem of my expectations being in the wrong place relative to marketing materials, etc. and not the fault of Full Traction at all.
In a nutshell, I understand that I'm an "early adopter" here, so my only hope is that others who are considering the same setup will have a few more things to know and watch out for when they do it themselves. That's why the forum exists, right?
