Front Trackbar Creaking?
Called Rockkrawler and they said i could try replacing the bushings they are only $5 for the pair.
Should I order them or try and grease it first?
Originally Posted by Trauma
Anyone?
How do I know if my bushings are shot?
Sorry but I don't quite get what I am looking for.
Are you saying put an object in the hole the bolt slides through and see if it is tight or has play? I presume it shoul have next to no play in it.
And your gonna move the screw driver around and see if the sleeve is loose on the rubber, or the rubber is cracked. U will see this when u apply pressure with the screwdriver if somethings worn.
Some minor movement of the rubber is normal but cracks and excessive movement is not normal.
