Front Track Bar Replacement on AEV 2.5 Lift
I have a 2013 Rubicon 2-door with a 2.5" AEV lift and I'm wanting to replace the front factory track bar. Can I pick from any track bar that made for small lifts or should I be concerned about how the track bar is bolted up to the AEV brackets?
From the JKS website, their front track bar states that they're not compatible with frame-mounted track bar drop brackets, which is I believe what AEV uses in order to keep the factory bar.
If an aftermarket track bar is designed like the factory except that it can be adjusted to make longer, why wouldn't one work with drop brackets?? The factory one works.
The front track bars I'm considering are JKS, Metalcloak, RockKrawler, and maybe TeraFlex. Any pointers is greatly appreciated!!!!.
Sent from my iPad using JK-Forum
From what I can tell, the AEV 2.5" kit does not come with any front track correction. I would look into the strongest trackbar possible, as it is such an important piece. My three suggestions are Synergy, RK, or Teraflex, Synergy being my #1 pick.
The teraflex his huge, adjustable on rig, and uses factory clevite joints at each end, but from my experiance will not work with a high steer setup (raised axle trackbar bracket and flipped drag link) as the bend in the link hits the sector shaft of the steering box at full passenger side compression without rediculous bumpstop.
The RK is the cheapest of the three, solid steel, and only has a light bend. Not adjustable on rig, and uses a non greasable poly joint at the frame. Works with standard bracket configuration and high steer.
Synergy is solid steel, adjustable on rig, uses a greasable poly bushing at the frame, is compatable with their sector shaft brace (brilliant piece), and works in factory orientation and high steer.
I would not recommend any other, especially JKS or FT as I have either seen them bend, or bent them myself on the trail.
I have the teraflex adjustable on mine I got It bwfofe I got the lift because my factory trackbar was pretty messed up lol . No problems with it
I kno aome people have complained about t in the past but I have had it now for 3 years with zero problems
