Front Track Bar for 2.5 " Lift
Old 06-27-2015 | 05:37 AM
Jlp10's Avatar
Veteran: Marine Corp
Default Front Track Bar for 2.5 " Lift
Just got a Teraflex 2.5" lift and I love it so far. The front axle moved about an inch to the drivers side. I am looking at the rubicon express adjustable track bar RE1673 to center the axle. Any thoughts ?
2007 Jeep JK
Old 06-27-2015 | 05:44 AM
LKWJeeper's Avatar
I know it's a lot more money but I'd go with the teraflex track bar. I've heard of the RE track bar ovaling out the frame side hole.
Old 06-27-2015 | 05:50 AM
SCHLEPPN02's Avatar
I was very happy with the TeraFlex trackbar on my last JK and ordered the same for my new one with the same TF 2.5" lift.
Old 06-27-2015 | 06:30 AM
TheDirtman's Avatar
Look at the synergy track bar, it has a double adjuster that makes it easy to adjust without removing. Raise the rear track bar with a axle side bracket for better handling.
Old 06-27-2015 | 04:49 PM
kjeeper10's Avatar
Vet Army
1" ? Seems a little excessive at 2.5 inches of lift?
How did you measure?
Old 06-27-2015 | 05:02 PM
drexelsteve's Avatar
My vote for JKS trackbar. Stock style bushings so it won't wear out like a rod end in a year. And this thing is BEEFY.
Old 06-27-2015 | 07:36 PM
Jlp10's Avatar
Originally Posted by kjeeper10
1" ? Seems a little excessive at 2.5 inches of lift? How did you measure?
Really I just eyeballed it, but it moved enough to to notice.
2007 Jeep JK
Old 06-27-2015 | 09:08 PM
Hoopskier's Avatar
Another vote for teraflex
Old 06-28-2015 | 02:42 PM
Jlp10's Avatar
I just measured it with a plumb-bob. The front is shifted to the drivers side by .5" and the rear is shifted to the drivers side by .75". I did not take this measurement before the lift. I am debating if I need to fix it at all?
Old 06-28-2015 | 03:55 PM
jadmt's Avatar
JK-Forum Ambassador
I doubt you will feel one iota of difference in how it drives so if aesthetically it does not bother you leave. I had about the same and went with a Tera flex bracket in the back and a RK adjustable in front. If I had to do it over I would skip the front but would still do the rear track bar bracket as it does raise the roll center where it should be.
Quick Reply: Front Track Bar for 2.5 " Lift
