Front Spacer only issues
Old 01-23-2009, 12:03 PM
DLEB's Avatar
Default Front Spacer only issues
Considering installing 1 3/4" front coil spacers only on my 2 door Rubicon. This looks like it would level the stance out. Is there any issues or problems I should be aware of if I go this route?
Old 01-23-2009, 01:06 PM
08RUBIJK's Avatar
1.75" in front might be a little too much... I have a 2dr Rubi with 1.75" front and 1" rear and it sits pretty much level...
I did not add bumpstop spacers or longer shocks - no problems.
Old 01-23-2009, 02:55 PM
jeepnxj3's Avatar
granted mine is an X but I just installed 1 3/4" spacers up front yesterday and was planning on just staying with that but it ended up being a little too high in the front and so i added the rear 1 3/4" spacer and I still have the rake. I might swap out the rear for a 1" like 08rubijk said. that should level her out. The front took like 45min to an hour, not hard what so ever.
Old 01-23-2009, 08:57 PM
aldaman's Avatar
Here's a pic of my unlimited with just a 1" front spacer....No issues with the install, straight forward install with no other adjustments needed...
Old 01-23-2009, 10:41 PM
JK-KJ's Avatar
yeah 1-3/4" might be a bit too much....but I do have some for sale if you're interested!
https://www.jk-forum.com/forums/jk-suspension-112/1-3-4-front-coil-spacers-68837/
Old 01-23-2009, 10:55 PM
JK-linux's Avatar
So, unless I'm wrong, a simple 3/4 to 1" spacer in from will reduct the "rake" ona JK Unlimited. No shock extensions or brake line extension needed?
Old 01-23-2009, 11:03 PM
aldaman's Avatar
Correct. I chose the 1" rather than the 3/4" spacer because I plan on installing an aftermarket front stubby bumper. Probably will be going with the shrockworks stubby unless something better comes along...
Old 01-24-2009, 12:25 AM
Rhino64's Avatar
Remove your spring isolator [rear] its about a 1/2" than you will be close to level. I have the same set-up and that what I did.
Old 01-24-2009, 05:13 AM
jeepnxj3's Avatar
Good thinking. I never thought about that. I might give that a try. Thanks!
Old 01-24-2009, 07:54 AM
TurkeyFreer's Avatar
Default 3/4" Spacer
I just did the 3/4" up front and left the factory isolator in and it is perfect. I have the stock bumper with a winch plate (no winch yet). With the weight of a winch on the front it will be perfectly level. Here are some shots and a link to the write up:
https://www.jk-forum.com/forums/jk-write-ups-39/installing-%BE%94-leveling-kit-hella-500ffs-custom-reverse-lights-69792/
Quick Reply: Front Spacer only issues
