Front spacer
Should post under Modified section. So, 1" pucks in front and 3/4" pucks in rear? Plan on bumpers, winch? Do you have recovery gear? When all those are accounted, then figure how much in front to level the rake.
Tires: probably the next thing you will look at. You can run skinny 33" with a possible steer stop adjustment-or- 33x12.5" with quality wheel spacers.
